pmoses
Apr 20, 2020Tutor
RBK853 connected devices incorrect
I have installed a new RBK853 mesh network. I installed the latest firmware. I can see the connected devices is just 13 when the actual number is 40+. Refresh or reboot does not fix the issue. Some o...
- Apr 22, 2020
I just did a factory reset (I had not done a factory reset after the firmware update.) and the connected devices seem to be showing up correctly now.
Hope I dont have to do a factory reset after every firmware update!
Apr 21, 2020Guru - Experienced User
Is this from the RBRs web page or from the Orbi app?
Are you using same SSID name and PW from prior wifi router configuration?
pmoses wrote:I have installed a new RBK853 mesh network. I installed the latest firmware. I can see the connected devices is just 13 when the actual number is 40+. Refresh or reboot does not fix the issue. Some of the devices use fixed IP's.
Do I need to do a full reset or is this a known issue that has no fix?
- pmosesApr 22, 2020Tutor
This is from both the mobile ios app and a browser.
Modem I use is the netcomm wireless NDD-0300. Its a VDSL2 FTTC modem.
https://www.zdnet.com/article/netcomm-wireless-unveils-fttc-network-connection-device/
The RBR850 is connecting to the internet via PPPoE.
Firmware of the RBR and 2x RBS850 is V3.2.10.11_1.2.12 (latest)
Same pwd and SSID from prior installation.
other 3rd party network apps on the app store are reporting correct info when connected to my network.
- FURRYe38Apr 22, 2020Guru - Experienced User
What devices are not appearing correctly on the RBRs web page and Orbi app?
