pmoses
Apr 20, 2020Tutor
RBK853 connected devices incorrect
I have installed a new RBK853 mesh network. I installed the latest firmware. I can see the connected devices is just 13 when the actual number is 40+. Refresh or reboot does not fix the issue. Some o...
- Apr 22, 2020
I just did a factory reset (I had not done a factory reset after the firmware update.) and the connected devices seem to be showing up correctly now.
Hope I dont have to do a factory reset after every firmware update!
Apr 22, 2020Guru - Experienced User
What devices are not appearing correctly on the RBRs web page and Orbi app?
pmoses
Apr 22, 2020Tutor
- FURRYe38Apr 22, 2020Guru - Experienced User
Great. Enjoy. :smileywink:
