vvemaraju
Dec 13, 2022Aspirant
RBK853 IOT network not present in Wireless settings
Hi, I have RBK853 which has RBR850 and 2 x RBS850. The manual says I can enable IoT network in Wireless settings but I can't find it in Wireless tab in orbilogin.com router config page. Is it...
Dec 13, 2022Guru - Experienced User
The IoT network is only seen on the 9 series Orbi system. It's not present on 3, 7 or 8 series systems.
- vvemarajuDec 13, 2022Aspirant
Thank you for your response, it makes sense. I am very surprised at this inclusion in page 57, 58 which led me to believe it exists somehow on Orbi 8 series??-
Orbi Whole Home Tri-Band Mesh WiFi 6 System User Manual (netgear.com)
- FURRYe38Dec 13, 2022Guru - Experienced User
Yes it is. I will inquire about this with NG.
Thank you. I appreciate the help in figuring this out and I was quite hopeful to segregate those devices.
- CrimpOnDec 13, 2022Guru - Experienced User
It might be helpful if Netgear could share a "comparison sheet" for the 850, 850, and 860 products.
The 860 having a 10G WAN port is one obvious difference, as is the mention of VPN
This is the first mention of VPN Client support in a Netgear router (as far as I am aware).
Would be interesting to know what else is different about the three models.
