vvemaraju
Dec 13, 2022Aspirant
RBK853 IOT network not present in Wireless settings
Hi, I have RBK853 which has RBR850 and 2 x RBS850. The manual says I can enable IoT network in Wireless settings but I can't find it in Wireless tab in orbilogin.com router config page. Is it...
vvemaraju
Thank you for your response, it makes sense. I am very surprised at this inclusion in page 57, 58 which led me to believe it exists somehow on Orbi 8 series??-
Orbi Whole Home Tri-Band Mesh WiFi 6 System User Manual (netgear.com)
Dec 13, 2022Guru - Experienced User
Yes it is. I will inquire about this with NG.
- vvemarajuDec 13, 2022Aspirant
Thank you. I appreciate the help in figuring this out and I was quite hopeful to segregate those devices.
- FURRYe38Dec 13, 2022Guru - Experienced User
All I can say is that NG has something planned however no idea when that will happen.
So for now you could use the Guest Network for some IoT items that some users have seem to have used. Just be aware that Guest Network wasn't really meant for long term use for devices has it' was initially intended for access of users that only needed connected for a short period of time.
- CrimpOnDec 13, 2022Guru - Experienced User
It might be helpful if Netgear could share a "comparison sheet" for the 850, 850, and 860 products.
The 860 having a 10G WAN port is one obvious difference, as is the mention of VPN
This is the first mention of VPN Client support in a Netgear router (as far as I am aware).
Would be interesting to know what else is different about the three models.
