Rikerrock
Jan 01, 2023Tutor
RBK853 Keeps disconnecting the satelites after newest Firmware
This unit doesn't seem to be disconneting from my fios net service (the router) but I will loose satelites and then they will reconnect after a few minutes. It's getting very annoying. Got 4 sateli...
Rikerrock
Jan 02, 2023Tutor
It's connected to a ONT in the garage. I turned off everything and then restarted. Currently seems ok. Holding breath. All sats are hardwired, so just did not compute as to why they'd try to sync via wifi to eachother. Thanks for the help.
Jan 02, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
