kg6qhd
Jan 02, 2021Aspirant
RBK853 Link Aggregation and Access Point Mode
Why is link aggregation turned off when I put the RBK853 (AX6000) system into Access Point mode? I don't see why this would be turned off. If I have a network system that can support that level o...
Jan 02, 2021Guru - Experienced User
LAG is a WAN to LAN supported feature only in router mode. Not LAN to LAN. It interfaces with a ISP modem that supports LAG on the WAN side only. Like NGs CM1100 and CM1200 cable modems.
