Superpapu
Nov 17, 2021Tutor
RBK853 lost conection
Hi, I need some help in order to solve the problem that i have with my rbk853 At least 3 times per week my router lost connection and i need to unplug in order to have internet again. Is no p...
Nov 17, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz. Disable AX mode on 2.4Ghz on the RBR.
Armor, Traffic Meter.
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
- SuperpapuNov 18, 2021Tutor
1 - V4.6.3.16_2.0.51
2 - The router is connected to the ONT, no company router. Im in spain3- 1 floor - 100m2
4- thats ok5.- auto in 2.4 and 36 in 5ghz
6- my mobile detect only 37. - done
8- done
there is any option to auto reboot when no internet is detected?
- FURRYe38Nov 18, 2021Guru - Experienced User
2 - The router is connected to the ONT, no company router. Im in spain Is there a brand and model# of the ONT?3- 1 floor - 100m2
8- done
there is any option to auto reboot when no internet is detected? No.
Does the front LED on the RBR/RBS turn ON when internet stops?
2 - The router is connected to the ONT, no company router. Im in spain Is there a brand and model# of the ONT? ONT NOKIA G-010-GP
The main router (orbi rbk) has a purple light in the front when internet is down.
Which is the best firmware for the rkb 853 ?Âż
