Superpapu
Nov 17, 2021Tutor
RBK853 lost conection
Hi, I need some help in order to solve the problem that i have with my rbk853 At least 3 times per week my router lost connection and i need to unplug in order to have internet again. Is no p...
Nov 17, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz. Disable AX mode on 2.4Ghz on the RBR.
Armor, Traffic Meter.
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Superpapu
Nov 18, 2021Tutor
1 - V4.6.3.16_2.0.51
2 - The router is connected to the ONT, no company router. Im in spain
3- 1 floor - 100m2
4- thats ok
5.- auto in 2.4 and 36 in 5ghz
6- my mobile detect only 3
7. - done
8- done
there is any option to auto reboot when no internet is detected?
- FURRYe38Nov 18, 2021Guru - Experienced User
2 - The router is connected to the ONT, no company router. Im in spain Is there a brand and model# of the ONT?3- 1 floor - 100m2
4- thats ok5.- auto in 2.4 and 36 in 5ghz
6- my mobile detect only 37. - done
8- done
there is any option to auto reboot when no internet is detected? No.
Does the front LED on the RBR/RBS turn ON when internet stops?
- SuperpapuNov 18, 2021Tutor
2 - The router is connected to the ONT, no company router. Im in spain Is there a brand and model# of the ONT? ONT NOKIA G-010-GP
The main router (orbi rbk) has a purple light in the front when internet is down.
Which is the best firmware for the rkb 853 ?Âż
Means the RBR has lost it's connection with the ONT or the ONT is no longer giving connections to the RBR.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
I'd contact the ISP and have them check the line up to the ONT and see if the ONT has any logs on these disconnections if they can tell anything on the ONT itself.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
I would power OFF the ISP ONT for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP ONT and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser. https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
