dtay
Aug 18, 2020Luminary
RBK853 Ping Lags/Drops - Network unusable this morning
I'm NOT a happy camper. So this morning, my wife mentioned that the Wi-Fi was having issues early this morning and woke me up. I noticed that all security cameras were offline and my phone was h...
dtay
Support ticket # 43245989 opened with Netgear.
Mindblowerz
Aug 18, 2020Aspirant
I'd try setting the CTS/RTS values back to 64. When I set mine to 2347, it brings the network down after a while, not immediate.
- dtayAug 18, 2020Luminary
Mindblowerz wrote:I'd try setting the CTS/RTS values back to 64. When I set mine to 2347, it brings the network down after a while, not immediate.
Really! How long was "after a while?" I wonder if that's the issue that I had experienced? But what's weird is that despite multiple reboots, I was still having the issue.
I checked the current setting for my ASUS RT-AC68U and it's at the defaults: 2347 for years. Don't recall having an issue with my ASUS on that setting (as I never touched it) but I'll try setting the Orbi back to 64 again when I set it up after hours again.
- FURRYe38Aug 18, 2020Guru - Experienced User
I know with v32 on my Orbi AX I had used 64 for CTS for days and didn't see any issues. Only with use of 2347 would I see some issues with NEST controllers disconnecting. NG is recommending use of default 64 for CTS on Orbi AX. Seems to work best on v32. I see v6 is now posted for manual download. I'll get mine loaded up and check operation with new FW.
FURRYe38 wrote:I know with v32 on my Orbi AX I had used 64 for CTS for days and didn't see any issues. Only with use of 2347 would I see some issues with NEST controllers disconnecting. NG is recommending use of default 64 for CTS on Orbi AX. Seems to work best on v32. I see v6 is now posted for manual download. I'll get mine loaded up and check operation with new FW.
Looking forward to hearing about your results with the new firmware.
- MindblowerzAug 18, 2020Aspirant
Yeah, "a while" sometimes mean a couple of hours, sometimes next day but it will eventually happen. Even tried the safe value of 500/512.. didn't bring down the network but definitely slowed it down.. so I'll back to 64. I've tested it multiple times to confirm... ask my wife lol
And yes, most other routers default to 2347 with no issues, not sure why it only happens with Orbi.
Orbi AX and the AX system seem to be one system where CTS 64 seems to be what NG has tuned with in the wifi drivers. Ya most N and AC wifi current and past was always set for 2347. Seems that isn't the case anymore for Orbi AX.
