dtay
Aug 18, 2020Luminary
RBK853 Ping Lags/Drops - Network unusable this morning
I'm NOT a happy camper. So this morning, my wife mentioned that the Wi-Fi was having issues early this morning and woke me up. I noticed that all security cameras were offline and my phone was h...
dtay
Mindblowerz wrote:I'd try setting the CTS/RTS values back to 64. When I set mine to 2347, it brings the network down after a while, not immediate.
Really! How long was "after a while?" I wonder if that's the issue that I had experienced? But what's weird is that despite multiple reboots, I was still having the issue.
I checked the current setting for my ASUS RT-AC68U and it's at the defaults: 2347 for years. Don't recall having an issue with my ASUS on that setting (as I never touched it) but I'll try setting the Orbi back to 64 again when I set it up after hours again.
Aug 18, 2020Guru - Experienced User
I know with v32 on my Orbi AX I had used 64 for CTS for days and didn't see any issues. Only with use of 2347 would I see some issues with NEST controllers disconnecting. NG is recommending use of default 64 for CTS on Orbi AX. Seems to work best on v32. I see v6 is now posted for manual download. I'll get mine loaded up and check operation with new FW.
- dtayAug 19, 2020Luminary
FURRYe38 wrote:I know with v32 on my Orbi AX I had used 64 for CTS for days and didn't see any issues. Only with use of 2347 would I see some issues with NEST controllers disconnecting. NG is recommending use of default 64 for CTS on Orbi AX. Seems to work best on v32. I see v6 is now posted for manual download. I'll get mine loaded up and check operation with new FW.
Looking forward to hearing about your results with the new firmware.
