dtay
Aug 18, 2020Luminary
RBK853 Ping Lags/Drops - Network unusable this morning
I'm NOT a happy camper. So this morning, my wife mentioned that the Wi-Fi was having issues early this morning and woke me up. I noticed that all security cameras were offline and my phone was h...
Aug 18, 2020Guru - Experienced User
I know with v32 on my Orbi AX I had used 64 for CTS for days and didn't see any issues. Only with use of 2347 would I see some issues with NEST controllers disconnecting. NG is recommending use of default 64 for CTS on Orbi AX. Seems to work best on v32. I see v6 is now posted for manual download. I'll get mine loaded up and check operation with new FW.
dtay
FURRYe38 wrote:I know with v32 on my Orbi AX I had used 64 for CTS for days and didn't see any issues. Only with use of 2347 would I see some issues with NEST controllers disconnecting. NG is recommending use of default 64 for CTS on Orbi AX. Seems to work best on v32. I see v6 is now posted for manual download. I'll get mine loaded up and check operation with new FW.
Looking forward to hearing about your results with the new firmware.
