dtay
Aug 18, 2020Luminary
RBK853 Ping Lags/Drops - Network unusable this morning
I'm NOT a happy camper. So this morning, my wife mentioned that the Wi-Fi was having issues early this morning and woke me up. I noticed that all security cameras were offline and my phone was h...
dtay
I've factory reset and got my Orbi AX up and operational.
Updated the router and the satellites to the latest firmware during the initial setup (it was required).
The CTS setting by default was already at 64 so I left it at that.
Keeping my fingers crossed that it doesn't break again!
dtay
Aug 19, 2020Luminary
OK, looks like I was overly optimistic. :(
Here's the full details.
Last night after everyone was asleep, I got the main router up and the two satellites factory reset, configured and back online. I was only able to put one satellite into production (via wired backhaul) and that was good. I wasn't able to bring the second one online as the room was occupied so I had to wait until morning.
Throughout the night, I had continuous pings running to the following:
192.168.1.1 - router
192.168.1.10 - satellite 1 (in production)
8.8.8.8 - google
Everything looked good, without a single drop on the pings and the network seemed fine.
This morning, when I plugged the second satellite in (wired backhaul), it came online. Within a few minutes, I noticed that my pings to the router, both satellites and to google were dropping. The issues that I had experienced earlier yesterday were occuring again; cameras, etc. were all going offline. I quickly disconnected the power to the second satellite and the pings resumed back to normal and everything came back online.
Here are the symptoms that I'm seeing:
-- In the GUI, under basic, home tab, for the box that says "attached devices", it shows the correct number of satellites: 1.
-- If I click on the attached devices box, it shows 2 satellites? Shouldn't it only show 1?
-- In the app (Android), it show 2 satellites as being online (the icons have the green LEDs). Shouldn't this only show 1?
I plan to reset the satellite that's offline currently but how do I remove it properly from the Orbi network? I don't see an option to remove or disassociate it from my current network from either the app or the GUI.
- Mikey94025Aug 19, 2020Hero
dtay wrote:The issues that I had experienced earlier yesterday were occuring again; cameras, etc. were all going offline. I quickly disconnected the power to the second satellite and the pings resumed back to normal and everything came back online.
This unfortunately sounds similar to the problem I'm having with my RBR850 system: https://community.netgear.com/t5/Orbi-AX/RBS850-satellites-lose-internet-and-gateway-connectivity-several/m-p/1959554#M5926. My symptoms are like yours: Internet and local network connectivity is lost but as soon as one "problemmatic" satellite is powered off, things work again. I tried a bunch of workarounds (as reported in that thread) but did not find anything that solved the intermittent connectivity issues.
I was hopeful that the new V3.2.16.6_1.4.4 firmware would be a fix, but after a couple days of goodness last night things went downhill again. I've given up trying to experiment and find a workaround so now I've factory reset both my RBR50 and RBR850, then swapped things so my old RBR50 is doing the routing and my RBR850 is hanging off of it in AP mode. I just want and need a stable network environment and can experiment with a new RBR850 firmware much further down the road when things are much more mature and they've worked out all these mysterious issues.
- FURRYe38Aug 19, 2020Guru - Experienced User
So you don't see Remove or Disconnect on the RBRs web page under Attached Devices at all?
What happens if you place this one RBS in place with the working RBS? Does it connect there?
Is the RBS directly connected to the RBR or is there a switch in between the non working RBS and the RBR?
Possible causes of what your seeing maybe a bad, sync, bad cable, bad RBS or bad switch.
I have both of my RBS online and wire connected. Both behind ethernet switches.
dtay wrote:OK, looks like I was overly optimistic. :(
8.8.8.8 - google
This morning, when I plugged the second satellite in (wired backhaul), it came online. Within a few minutes, I noticed that my pings to the router, both satellites and to google were dropping. The issues that I had experienced earlier yesterday were occuring again; cameras, etc. were all going offline. I quickly disconnected the power to the second satellite and the pings resumed back to normal and everything came back online.Here are the symptoms that I'm seeing:
- dtayAug 19, 2020Luminary
Both satellites are connected to a switch that's connected back to the Orbi. The switch is fine; I've connected my laptop to the same port where the Orbi was and my laptop connected fine.
See attached screen cap from the GUI. It shows both satellites even though one is unplugged and turned off. :) Is that normal?
Here's another oddity: I factory reset the offending satellite (pin reset 30 seconds until light is amber; while still holding down the pin, unplug power, and plug back power for another 30 seconds before releasing the pin) and when it came up, I was surprised that I could still login to the AP (with the default cred. of admin/password) and it still showed as configured to my Orbi network. How is that possible when I've already reset it several times?
What is the mfr and model of this switch?
If the RBS was turned off and you gave several minutes for the RBRs web page to update, the RBS should show as disconnected.
So swap RBSs around and see if the one non working RBS works in the others place while the working one is turned off and disconnected.
You only need 15 seconds press of the reset button then release. Be sure you feel the button press in with the small feel of a bump when you press it.
Possible you may have a faulty RBS as well.
FURRYe38 wrote:What is the mfr and model of this switch?
Switch is a Netgear GS116 16-port gig switch.
I'm going to reboot the router tonight to see if it will update the RBR devices web page properly; the offending satellite has been turned off for several hours now yet the page still says it's connected and "good." LOL!
I can can try swapping the RBS aound but don't think that will make a difference since they are both connected to the same switch; just different rooms at the opposite sides of the house (same floor).
Please try swapping the RBS around just to see.
What version or rev is the switch? I see a few different revs for this model switch.
FURRYe38 wrote:Please try swapping the RBS around just to see.
Not sure what rev or version of the switch it is as it is a few years old and is currently mounted on the panel. I'd have to unpatch the switch, unscrew it from the rack to get to the label and that's not a possible. It's the GS116NA - https://smile.amazon.com/NETGEAR-Ethernet-Unmanaged-Protection-GS116NA/dp/B00023DRLO/ref=psdc_281414_t1_B00AQO19KK
Update: I was able to reboot the router a few moments ago when everyone in the household was having lunch so I quickly did that. Sure enough, it now properly shows the RBS that's been turned off as being disconnected and gave me the option to remove it; see screen cap. It's strange (and unsettling) why the router kept saying the disconnected RBS was still connected earlier.
Ok so did you remove the one RBS?
Possible the RBR was stuck in a bad state and needed a reboot.
Reason for asking is that there are several different models and revs for the 116 switch trying to attempt to see which one you have for additional specs on your switch. Just to make sure.
Thanks for the heads up. This has been a frustrating and weird issue, one that I didn't expect from what is supposed to be a flagship wireless mesh solution.
FURRYe38 wrote:Ok so did you remove the one RBS?
Yup, I've removed the offending RBS and now the RBR shows just one RBS connected. :)
I will try and connect the RBS again sometime after hours when no one is on the network and see if the symptoms happens again. If it does, then I'll push NG for an RMA for a bad RBS.
OK, Keep us posted.
I would factory rest the RBS 15 second press then release. Then re-add it to the RBR using the sync button on the RBS and then press the sync button on the RBR or use the RBRs web page add satellite feature to add it. I would do this while in same room with the RBS and RBS. Add it wirelessly first, let it sync and give about 5 minutes for the RBS and RBR to settle in. check the status on the RBRs web page. Wireless 5G should appear. Check the RBS status page as well, make sure the SSID and Security are enabled. Once it's settled in, then connect the ethernet cable to the RBS. Then again check the RBRs status. Give a few minutes for the RBR to report the change in connection. Check the status page on the RBS. SSID and security should be enabled and both 2.4 and 5Ghz single icons on the left side should be grayed out.
- dtayAug 20, 2020Luminary
FURRYe38 wrote:OK, Keep us posted.
Update on my progress last night adding the RBS back:
I followed the exact steps above (resetting the RBS again, for the thousand time) and the RBS connected and joined the network wirelessly and after about 10 minutes or so (on wireless), I moved it to the bedroom where it is intended to be, and connected it back (wired). I also set the DHCP reservation for the RBS back to what I want it to be (192.168.10) since my DHCP pool begins at .100 and the RBS was at .134. Despite setting the DHCP reservation and rebooting all the units, it still kept the DHCP address (.134) and the reservation didn't kick in until about 10 am this morning, so that's about 12 hours later. I'm disappointed that the firmware doesn't allow you to change the DHCP lease time. C'mon.
Continuous pings to the RBR and the two RBS since turning up the second RBS have been stable and consistent so far <knock on wood>. All units are at the latest firmware (V3.2.16.6_1.4.4). No issues with DNS as well (using 1.1.1.1 and 8.8.4.4). CTS/RTS at 64.
Let's hope it stays that way! Will continue to monitor.
- FURRYe38Aug 20, 2020Guru - Experienced User
So you set a IP address reservation ON the RBR for the RBS at "(192.168.10)" ? 10? IF .10, this is outside of the .100 to .254 range and should not be setting a IP address reservation for a IP address thats out side the DHCP pool, I would remove the reservation. IP address reservations are for devices with IN the DHCP IP address pool. If you set a smaller DHCP pool size, then anything outside this pool size is used for STATIC IP addressed devies which are SET ON devices, NOT on the router. This maybe one reason why your seeing problems. I set IP address reservations for my two RBS in the pool, .101 and .102. These are working for me.
- dtayAug 21, 2020Luminary
FURRYe38 wrote:So you set a IP address reservation ON the RBR for the RBS at "(192.168.10)" ? 10? IF .10, this is outside of the .100 to .254 range and should not be setting a IP address reservation for a IP address thats out side the DHCP pool, I would remove the reservation. IP address reservations are for devices with IN the DHCP IP address pool. If you set a smaller DHCP pool size, then anything outside this pool size is used for STATIC IP addressed devies which are SET ON devices, NOT on the router. This maybe one reason why your seeing problems. I set IP address reservations for my two RBS in the pool, .101 and .102. These are working for me.
Update: I made the changes last night for the DHCP reservations IPs for the RBS to .101 and .102 rebooted everything. So far, everything seems to be stable. Continuous pings to the RBR, RBS and to www.yahoo.com have been consistent and stable, with no drops for the last 6+ hours so far as of this writing. DNS resolutions (using 1.1.1.1 and 8.8.4.4) are working fine so far. Keeping my fingers crossed! :)
