dtay
Aug 18, 2020Luminary
RBK853 Ping Lags/Drops - Network unusable this morning
I'm NOT a happy camper. So this morning, my wife mentioned that the Wi-Fi was having issues early this morning and woke me up. I noticed that all security cameras were offline and my phone was h...
dtay
Aug 19, 2020Luminary
FURRYe38 wrote:Please try swapping the RBS around just to see.
What version or rev is the switch? I see a few different revs for this model switch.
Not sure what rev or version of the switch it is as it is a few years old and is currently mounted on the panel. I'd have to unpatch the switch, unscrew it from the rack to get to the label and that's not a possible. It's the GS116NA - https://smile.amazon.com/NETGEAR-Ethernet-Unmanaged-Protection-GS116NA/dp/B00023DRLO/ref=psdc_281414_t1_B00AQO19KK
Update: I was able to reboot the router a few moments ago when everyone in the household was having lunch so I quickly did that. Sure enough, it now properly shows the RBS that's been turned off as being disconnected and gave me the option to remove it; see screen cap. It's strange (and unsettling) why the router kept saying the disconnected RBS was still connected earlier.
Aug 19, 2020Guru - Experienced User
Ok so did you remove the one RBS?
Possible the RBR was stuck in a bad state and needed a reboot.
Reason for asking is that there are several different models and revs for the 116 switch trying to attempt to see which one you have for additional specs on your switch. Just to make sure.
- dtayAug 19, 2020Luminary
FURRYe38 wrote:Ok so did you remove the one RBS?
Yup, I've removed the offending RBS and now the RBR shows just one RBS connected. :)
I will try and connect the RBS again sometime after hours when no one is on the network and see if the symptoms happens again. If it does, then I'll push NG for an RMA for a bad RBS.
- FURRYe38Aug 19, 2020Guru - Experienced User
OK, Keep us posted.
I would factory rest the RBS 15 second press then release. Then re-add it to the RBR using the sync button on the RBS and then press the sync button on the RBR or use the RBRs web page add satellite feature to add it. I would do this while in same room with the RBS and RBS. Add it wirelessly first, let it sync and give about 5 minutes for the RBS and RBR to settle in. check the status on the RBRs web page. Wireless 5G should appear. Check the RBS status page as well, make sure the SSID and Security are enabled. Once it's settled in, then connect the ethernet cable to the RBS. Then again check the RBRs status. Give a few minutes for the RBR to report the change in connection. Check the status page on the RBS. SSID and security should be enabled and both 2.4 and 5Ghz single icons on the left side should be grayed out.
- dtayAug 20, 2020Luminary
FURRYe38 wrote:OK, Keep us posted.
Update on my progress last night adding the RBS back:
I followed the exact steps above (resetting the RBS again, for the thousand time) and the RBS connected and joined the network wirelessly and after about 10 minutes or so (on wireless), I moved it to the bedroom where it is intended to be, and connected it back (wired). I also set the DHCP reservation for the RBS back to what I want it to be (192.168.10) since my DHCP pool begins at .100 and the RBS was at .134. Despite setting the DHCP reservation and rebooting all the units, it still kept the DHCP address (.134) and the reservation didn't kick in until about 10 am this morning, so that's about 12 hours later. I'm disappointed that the firmware doesn't allow you to change the DHCP lease time. C'mon.
Continuous pings to the RBR and the two RBS since turning up the second RBS have been stable and consistent so far <knock on wood>. All units are at the latest firmware (V3.2.16.6_1.4.4). No issues with DNS as well (using 1.1.1.1 and 8.8.4.4). CTS/RTS at 64.
Let's hope it stays that way! Will continue to monitor.
- FURRYe38Aug 20, 2020Guru - Experienced User
So you set a IP address reservation ON the RBR for the RBS at "(192.168.10)" ? 10? IF .10, this is outside of the .100 to .254 range and should not be setting a IP address reservation for a IP address thats out side the DHCP pool, I would remove the reservation. IP address reservations are for devices with IN the DHCP IP address pool. If you set a smaller DHCP pool size, then anything outside this pool size is used for STATIC IP addressed devies which are SET ON devices, NOT on the router. This maybe one reason why your seeing problems. I set IP address reservations for my two RBS in the pool, .101 and .102. These are working for me.
- dtayAug 21, 2020Luminary
FURRYe38 wrote:So you set a IP address reservation ON the RBR for the RBS at "(192.168.10)" ? 10? IF .10, this is outside of the .100 to .254 range and should not be setting a IP address reservation for a IP address thats out side the DHCP pool, I would remove the reservation. IP address reservations are for devices with IN the DHCP IP address pool. If you set a smaller DHCP pool size, then anything outside this pool size is used for STATIC IP addressed devies which are SET ON devices, NOT on the router. This maybe one reason why your seeing problems. I set IP address reservations for my two RBS in the pool, .101 and .102. These are working for me.
Update: I made the changes last night for the DHCP reservations IPs for the RBS to .101 and .102 rebooted everything. So far, everything seems to be stable. Continuous pings to the RBR, RBS and to www.yahoo.com have been consistent and stable, with no drops for the last 6+ hours so far as of this writing. DNS resolutions (using 1.1.1.1 and 8.8.4.4) are working fine so far. Keeping my fingers crossed! :)
