knowyourlimits
Sep 28, 2020Aspirant
RBK853 (RBR850 + 2 sat) and iTunes Home Sharing
I recently installed the AX6000 RBK853 (with 2 sat) and cannot get iTunes Home Sharing to work in wireless mode. The satellites are hardwired and everything but Home Sharing is working very well. Scr...
Sep 28, 2020Guru - Experienced User
Something to ask APPLE support about...
knowyourlimits
Sep 29, 2020Aspirant
I took your advice. No responses yet. I think this more to do with router/satellite/switch config, but I'm not skilled enough to prove it. Appreciate your rapid response.
FURRYe38 wrote:Something to ask APPLE support about...
- FURRYe38Sep 29, 2020Guru - Experienced User
What is the mfr and model # of the switch used in between the RBR and RBS?
Something to test out:Turn OFF The RBS. Does home sharing work with just the RBR alone?
Turn ON the RBS and wirelessly connect it to the RBR. Connect something to the RBS that you want to share. Does this work?
Reverse devices, connect something at the RBS and share something on the RBR side. Work here?
