Superpapu
Oct 19, 2021Tutor
Rbk853 satellite 2.4ghz
Hi, I have the rkb853. I detect that all the devices are connected to the main router (2,4 and 5ghz) and none to the satellites even if the device is close to the satellite. The satellites has 2...
Superpapu
Oct 19, 2021Tutor
Hi
4.6.3.16_2.0.51
the router is connected directly to the ont. the provider is Movistar (Spain). In general the wifi is perfect, it just the devices don't connect to the satellites
is a 860 sq flat in 1 level.
the distance is 150 sq with the first one and 300 sq with the second
is up to client devices to pick and choose where they connect too.
You can try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
you said to disable the "wifi" in the Orbi app in the devices that I want in order see if that would solve the problem
Oct 19, 2021Guru - Experienced User
860 sq Feet or Meters?
"you said to disable the "wifi" in the Orbi app in the devices that I want in order see if that would solve the problem" No this is not what I said. >You can try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings < this is done thru the RBR web page using a web browser.
- SuperpapuOct 19, 2021Tutor
the house is 100m2 and the distance with the first satellite is 15m and with the second 25m.
Here you can see all the devices to the main router and none to the satellites
- FURRYe38Oct 19, 2021Guru - Experienced User
What happens if you turn down the power output of the RBRs wifi radios from 100% to 25% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings < this is done thru the RBR web page using a web browser.
