ReflectedBlack
Jun 04, 2020Initiate
RBK853 Satellite Connection
Hello! Need some help. I just hooked up the Orbi RBK853 and the router is so powerful that my devices do not switch to the satellites when closer to them. So, I’m getting great speeds closer to router...
Jun 04, 2020Guru - Experienced User
Yes they can be placed farther out than 30 feet as well. 50-60 feet would be a good limit on distance depending upon building materials.
You can also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
