wouterlet
Oct 28, 2020Aspirant
RBK853 seems to have no internet for a sec after opening connection
I have an RBK853, the connectionrange is great. Speed is very good. But I have the thing when I open a website on my phone or laptop for a sec there is an an error DNS_PROBE_FINISHED_NXDOMAIN. When I...
Oct 28, 2020Guru - Experienced User
If your ISP modem has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I recommend trying option #2 first...
arlomike
Oct 28, 2020Apprentice
Sounds like the infamous DNS issue with Orbi. Do a search on this forum
- FURRYe38Oct 28, 2020Guru - Experienced User
Let check the configuration of the modem first...they maybe in a double NAT condition.
- wouterletOct 28, 2020Aspirant
Thanks for your answer! I found multiple DNS problem threats but without a real solution. Did I miss the solution or does Neatgear sell €1200 products that can't even handle the most basic actions???
