wouterlet
Oct 28, 2020Aspirant
RBK853 seems to have no internet for a sec after opening connection
I have an RBK853, the connectionrange is great. Speed is very good. But I have the thing when I open a website on my phone or laptop for a sec there is an an error DNS_PROBE_FINISHED_NXDOMAIN. When I...
wouterlet
Thanks for your answer! The first option is sadly impossible. I called them a few times but the same answer everytime....
I think option 2 is allready the situation here. I attached a screenshot. But I had my Orbi already set as exposed host to be able to connect to my domotica.
Can you check if I'm right? Could it still be helpfull to test option 3? I'm not excited to test it since I set up multiple fixed IP adresses and hope other devices won't get problems.
Oct 28, 2020Guru - Experienced User
I would ask the ISP about if your Exposed Host configuration is correct. It looks like it.
Been a known issue as well that some ISP modems DMZ or Exposed Hosts may not work well.
Yes, try AP mode with the RBR850. You'll need to remove the Exposed Host configuration from the modem though when you do this.
- wouterletNov 09, 2020Aspirant
Sorry for the delay.Thanks for your answers. I'm currently in discussion with Netgear from The Netherlands, they are giving support still. So I'll leave it to them for now. If I find the solution I'm coming back here!
- FURRYe38Nov 09, 2020Guru - Experienced User
Thank you for the update.
