andwheeler
Dec 18, 2020Aspirant
RBK853 Solid White Light After Power Cut
Firmware Version V3.2.16.22_1.4.9 We had a couple of power cuts last weekend and since then the LED on the modem has stayed on solid white. I have tried power cycling etc. but the light remains on. ...
andwheeler
Yes, sorry on the router. I have tried switching both ISP ONT & router off for 30secs then switching on the ISP ONT on then router once that booted up and showing green status. White light remains on solid on router. Thank you
Dec 18, 2020Guru - Experienced User
Be sure your using a good quality LAN cable between the ONT and RBR. Cat 6 is recommended.
You might try a factory reset on the RBR and setup from scratch..
