thunt002
May 18, 2020Tutor
Rbk853 unavailable
Finally ready to drop the big coins on the Orbi RBK853 and it is not available ANYWHERE. What was a bit concerning was that one vendor reported that it was recently discontinued and would not be avail...
- May 18, 2020
I would review and compare the spec sheets for each system. Look at the wifi connection rates listed at the bottom of each system. This and MIMO and stream data information will tell you what system does and compare the two.
Where did you hear about Orbi AX being discontinued?
Orbi AX is still listed in NGs shop:
The system hasn't been out for a year yet. NG doesn't make something and spend lots of design and development money on something that they would turn around and discontinue it.
thunt002
May 18, 2020Tutor
I briefly considered the Nighthawk Mesh System. But the performance and lack of multiple ethernet ports compared to the Orbi was not aligned with my needs.
kildare
May 18, 2020Luminary
Maybe Netgear is developing an Orby AX6000 v.2 to overcome the current hardware limitations and problems.
Let's see...
