thunt002
May 18, 2020Tutor
Rbk853 unavailable
Finally ready to drop the big coins on the Orbi RBK853 and it is not available ANYWHERE. What was a bit concerning was that one vendor reported that it was recently discontinued and would not be avail...
- May 18, 2020
I would review and compare the spec sheets for each system. Look at the wifi connection rates listed at the bottom of each system. This and MIMO and stream data information will tell you what system does and compare the two.
Where did you hear about Orbi AX being discontinued?
Orbi AX is still listed in NGs shop:
The system hasn't been out for a year yet. NG doesn't make something and spend lots of design and development money on something that they would turn around and discontinue it.
thunt002
May 18, 2020Tutor
I was not clear - I understand the point regarding the equivalency of ethernet throughput. My question is does the WiFi performance of the NG Mesh System compare to the Orbi? My understanding is that it does not but I don’t have any real world experience to back that up.
The answer may very well be to wait for the Orbi to be restocked if it is not being discontinued as was reported.
May 18, 2020Guru - Experienced User
