pbomberg
Sep 25, 2020Aspirant
RBK853 vs RBK852
My house is not that large 2,500Sqft but it’s older 1913 and has solid brick walls internally as well as lathe and plaster walls which block the signal, it is also 3 stories plus basement (where the ...
Chuck_M
Sep 25, 2020Mentor
If available and if cost is not prohibitive, I would recommend the 853 since you get an additional satellite -- considering the construction of your home. Better safe than sorry/
pbomberg
Thanks that is the real crux, I live in Ottawa, Ontario, Canada and I can easily get the RBK852 but I cant find anyone selling the RBK853, otherwise I would have bought it without hesitation
