vveduvv
Dec 12, 2019Aspirant
RBK853 wireless region
Dear all, I've recently purchased an Orbi RKB853 system and everything works OK but I have some problems regarding the Wifi connected devices. They appear to be connected but after a random time betwe...
vveduvv
Hi,
Already tried it, but no luck:
root@RBR850:/# rm /tmp/firmware_region
rm: can't remove '/tmp/firmware_region': No such file or directory
Dec 12, 2019Guru - Experienced User
Possible that the Orbi AX isn't supporting of other reagions as of yet. Or the US versions can't be changed.
You might contact NG support about this and see.
- vveduvvDec 12, 2019Aspirant
Thanks FURRYe38. I just opened a ticket, I'll keep you updated with the NG support response
Regards
- mrbrightside1Dec 18, 2019Aspirant
Any update?
- vveduvvDec 18, 2019Aspirant
No news from NG support since last Thursday (Dec 12th). I'll ask again.
Keep you updated
