Snakepottery
Nov 25, 2020Aspirant
RBK853
Hi, Looking at maybe purchasing the RBK853 or 753. Looking through reviews there does seem to be fair few issues with the 853 and compatibility with some streaming services as well as poor range....
Snakepottery
Nov 26, 2020Aspirant
Thnkas for the quick and comporehensive replies!
I'm thinking that the 853 is massive overkill given I have a small 3 bed house with around 49m2 ground floor. The router will be upstairs probably 15m as the crow flies from the satelite. Also, do I really need AX? Ther will be about a max of 6 devices connected of which only two are AX compatible. I dont do any gaming, just browsing and streaming of course. I like the idea of future proofing (as much as you can with IT!) but not keen on wasting money either.
Thanks
Snakepottery
What about the RBK23? Looks more suitable for my needs? And a sensible price!!
Thanks
- FURRYe38Nov 26, 2020Guru - Experienced User
IF you feel you don't need AX mode and you only do general internet access, then the Orbi AX would be something to look into and review. However if you see a good deal or special on a Orbi AX system during the holidays, maybe something to consider if you can find a good price on one.
Good Luck.
