Retired_Member
Apr 16, 2024RBK853
Hi I'm considering upgrading my broadband connection to 2Gbps and wanted to check that the RBK853 system had a multi Gb port I can use to maximise the speeds or if I need to upgrade? Thanks in a...
- Apr 17, 2024
It looks like the RBK853 has a 2.5gig wan port.
https://www.netgear.com/home/wifi/mesh/rbk853/
It doesn't have multigig lan ports through
Apr 17, 2024Guru - Experienced User
