vfromdc's avatar
vfromdc
Guide
Jun 30, 2024
RBK853
I noticed that my RBK853 system now allows iot networks (both 2.4 and 5.0 GHz). That is good news. My question is, "Will devices on iot networks have visibility to my main networks? in other words, ...
  • CrimpOn's avatar
    CrimpOn
    Jul 01, 2024
    The very first Orbi series (2016) had an option for the Guest Network:
    Every Orbi system since then has no option for the Guest WiFi network.  Devices on Guest WiFi have only internet access and cannot access (or be accessed from) the primary network.
    The Internet of Things (IoT) WiFi network was introduced in a firmware update to some of the Orbi AX products (but not all - sigh).  This is an obvious attempt to address the issue of IoT devices which are difficult to set up when both 2.4G and 5G WiFi have the same SSID due to poorly written smartphone apps.  Devices on the IoT WiFi network are part of the primary network and fully accessible.
