Emmanuel666
Apr 23, 2021Tutor
RBK854 - System AX6000 et Répéteur Wifi Mesh d’extérieur
Bonjour, je suis l'heureux propriétaire d'un système RBK854 (AX6000), mais je dois encore couvrir une partie jardin devant et derrière la maison. Sauriez vous m'indiquer quel modele d'exterieur se...
- Apr 25, 2021
Thank for your answer FURRYe38 .
But RBS50Y or RBS50Y v2 aren't WIFI6 extender :(
Apr 24, 2021Guru - Experienced User
The only outdoor model that works with Orbi AX would be the RBS50Y, however you need to load the extender mode FW on the RBS50Y first.
- Emmanuel666Apr 25, 2021Tutor
But RBS50Y or RBS50Y v2 aren't WIFI6 extender :(- FURRYe38Apr 26, 2021Guru - Experienced User
They are only WiFi 5. There is no WiFi 6 outdoor extender currently.
