rsun0525
Jan 07, 2021Guide
RBK854, Satellites don't sync through Ethernet backhaul
I've got an RBK854 (1 RBR850 + 3 RDS850's). Setup seemed to work just fine, can put all 4 devices in a room and can get them all to sync up just fine wireless. I then move the satellites to vari...
- Jan 16, 2021
I would presume that you may have had a faulty unit rather than a bug. I know mines working in AP mode and both RBS ARE ethernet connected and is working fine.
Glad you found something.
Enjoy.
rsun0525
Jan 07, 2021Guide
It's the latest firmware. V3.2.16.22_1.4.9
If there's a newer one somewhere I can manually install, I'd be happy to try.
Yes I did the sync all wirelessly, do I need to do the sync again but have them all wired next to each other?
I've seen that URL many times, and yes, I'm sure I'm not doing something silly.
As I mentioned previously I've done this exact same Ethernet backhaul thing with Google and Linksys Velop.
Does wired syncing initially not the same as syncing wirelessly initially?
Jan 07, 2021Guru - Experienced User
IT's best to wirelessly synce first each RBS then connect them wired.
- rsun0525Jan 07, 2021Guide
Yes this is what I did. I just tested it again and I took the 3 satellites and put them next to the router, they all synced automatically, I didn't have to do anything. I then tried to reset the authentication for the sync, and it worked perfectly. I then took each satellite and one at a time put them in the remote rooms connected through Ethernet and the one I moved would no longer say it's connected to the router, etc. I confirmed the satellite is working by pinging it and webbing into it, I can also see it hosting many Wi-Fi devices. It's just a puzzle to me why Ethernet backhaul is not working from a sync point of view, but everything else I can check seems to be working.
From what I can tell, as long as I don't change the configuration, then I don't actually need to sync, but obviously the mobile app is even more useless as only when I'm connected to the router specifically does it show up, etc, if I'm not connected to the router through Wi-Fi, it says nothing is there, etc.
- FURRYe38Jan 07, 2021Guru - Experienced User
Does the RBS sync near the RBR with a LAN cable connected directly to the RBR and RBS with out the switch in between?
Your Switch is a managed switch, there are known problems with these swtitches. Disable ALL IGMP protocols on this switch and if you can disable any Green Ethernet features.
NG GS-105/108v4, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
- rsun0525Jan 09, 2021Guide
I confirmed that the my managed switch had IGMP disabled, had green disabled, etc. To prove the point, I went out and purchased a 5-Port Gigabit Ethernet Unmanaged Switch (GS105NA) - Desktop, and ProSAFE Limited Lifetime Protection and connect the 4 devices for my Ethernet backhaul and it's still not working. So this is not related to using my managed switch. The only other thing I can think of is that I'm using it in AP mode. Is there some bug because it's in AP mode and not router mode?
So is your only suggestion is that I have to put all the 4 devices together in the same room and connected my Ethernet and see if it syncs?
