rsun0525
Jan 07, 2021Guide
RBK854, Satellites don't sync through Ethernet backhaul
I've got an RBK854 (1 RBR850 + 3 RDS850's). Setup seemed to work just fine, can put all 4 devices in a room and can get them all to sync up just fine wireless. I then move the satellites to vari...
- Jan 16, 2021
I would presume that you may have had a faulty unit rather than a bug. I know mines working in AP mode and both RBS ARE ethernet connected and is working fine.
Glad you found something.
Enjoy.
rsun0525
Jan 16, 2021Guide
I'm going to make the assumption I found some sort of software bug with the latest firmware for the RBR850/RBS850.
I was able to return it to the vendor and instead I purchased the Orbi Pro SXR80/SXS80's, etc
Exact same setup 1 router and 3 satellites and it looks like the Ethernet backhaul is working right.
I was able to configure it by finding the IP address and going to it from my PC. After it was all setup, I can see the router reporting under Attached Devices that 3 Satellites are connected, and when I go to Attached Devices I can see the 3 satellites are listed as wired.
This is a sigh of relief as I never saw any of this in the web pages of the Orbi RBR850/RBS850's, so I'm definitely much happier, just have to figure out why my iPhone and Android versions of the Orbi app won't connect to it.
Jan 16, 2021Guru - Experienced User
Enjoy.
