senator1949
Sep 28, 2025Aspirant
RBK863S IPv4 assignment
My Orbi RBK863S was first installed as a router, but later changed to an Access Point to reduce conflict with my AT&T gateway/router. However, my PC is still getting assigned 10.x.x.x IPv4 addresses ...
- Sep 30, 2025
Thanks to all who responded. Here is an update.
It appears the culprit for my not getting internet access on my Ethernet connection had to do with my VPN (Nord). When I changed the setting to NOT launch on startup, My PC was given a 192.168.1.X local IP address. Not sure I'm out of the woods yet and will need a few more reboots to feel confident. Thanks again.
senator1949
Sep 30, 2025Aspirant
- FURRYe38Sep 30, 2025Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-SystemEnjoy. 📡
