Theronnyc
May 17, 2023Follower
RBK863S keeps dropping signal from ethernet connection
My router keeps dropping the internet connection. It's connected via an ethernet cable, so I don't think it's the signal. I notice that when I turn off one of the satellites that the signal doesn't d...
May 17, 2023Guru - Experienced User
Does the front LED turn ON Pink when this happens?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
