yili_zhao
Dec 08, 2021Follower
RBK960 upgrade firmware issues
After upgraded the firmware on RBRE 960 from V6.0.3.50 to V6.0.3.68, I can't access the website. After factory defaut reset, I can ping to 192.168.1.1 but can't access the website. Any idea? Than...
michaelkenward
Dec 09, 2021Guru - Experienced User
While many issues are generic and will apply to most routers, in this case you are asking about firmware. And that depends on the model number.
The RBRE960 is a fancy Orbi device rather than one of the Nighthawk Routers with WiFi 6 (AX) and WiFi 6E (AXE) devices covered here.
You might get more informed responses over in the section where they cover your hardware:
Orbi WiFi 6 (AX) and WiFi 6E (AXE) - NETGEAR Communities
