yili_zhao
Dec 08, 2021Follower
RBK960 upgrade firmware issues
After upgraded the firmware on RBRE 960 from V6.0.3.50 to V6.0.3.68, I can't access the website. After factory defaut reset, I can ping to 192.168.1.1 but can't access the website. Any idea? Than...
Dec 09, 2021Guru - Experienced User
What browser are you using to access the RBRs web page? Try MS Edge, Firefox or Opera.
Be sure your connected with the RBR with a LAN cable to test.
Try a different PC or laptop.
