x19
Sep 07, 2022Guide
RBK963 6.3.1.21
Any update in relation to this FW? if it was installed, do we need to downgrade? WHy was it pulled?
- Sep 20, 2022
Ok. Glad ethernet worked. It should have. Unless the FW is way off or the RBS are in some bad condition.
Will keep asking about bringing the RBS self web page services back. It was available on the 8 series early on but someone decided to take it away. Would have been nice to have it here.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Mikey94025
Sep 07, 2022Hero
I upgraded my AXE Orbi system to 6.3.1.21 very soon after it came out, but then had issues and rolled back. It was pulled from https://www.netgear.com/support/download/?model=RBKE963 soon after. I would recommend running the latest FW release on the downloads page or anything that is offered as auto-update. I don't believe 6.3.1.21 falls into either of these categories right now.
x19
Sep 09, 2022Guide
What issues were you having? I didn't notice any difference between this and the previous version.
I would have thought that netgear would make an official communication on the matter
- FURRYe38Sep 10, 2022Guru - Experienced User
I was told that it was pulled due to failing testing and should have not been posted in the first place. So only use what is seen on NG download page or here in the forums.
If your having problems please post about them and give details and we'll try and help you out.
- x19Sep 10, 2022Guide
Dont seem to have any issues, just wondering if I still have to downgrade
