x19
Sep 07, 2022Guide
RBK963 6.3.1.21
Any update in relation to this FW? if it was installed, do we need to downgrade? WHy was it pulled?
- Sep 20, 2022
Ok. Glad ethernet worked. It should have. Unless the FW is way off or the RBS are in some bad condition.
Will keep asking about bringing the RBS self web page services back. It was available on the 8 series early on but someone decided to take it away. Would have been nice to have it here.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Sep 11, 2022Guru - Experienced User
There working on something else.
x19
Sep 13, 2022Guide
sorry what do you mean
- FURRYe38Sep 13, 2022Guru - Experienced User
Other FW.
- RafSSep 14, 2022Apprentice
I left 6.3.1.21 on my RBK963 and my firmware had recently been updated to 6.3.5.8 but I don't know when this update happened. I haven't really been home to observe if anything had broken but my cameras are working which is my main concern right now.
- TC_in_MontanaSep 14, 2022Virtuoso
I have a question into NG Support about this. Nothing in the download pages for this version, no release notes. Hoping to have an answer shortly.
- x19Sep 20, 2022Guide
Since I rebooted the router I can not get the satellites to connect. How do I download the firmware to .85? Do I have to connect the laptop to each satellite?
- FURRYe38Sep 20, 2022Guru - Experienced User
I would downgrade the RBR back to v.85 as I presume the RBS are still at v.85?
