x19
Sep 07, 2022Guide
RBK963 6.3.1.21
Any update in relation to this FW? if it was installed, do we need to downgrade? WHy was it pulled?
- Sep 20, 2022
Ok. Glad ethernet worked. It should have. Unless the FW is way off or the RBS are in some bad condition.
Will keep asking about bringing the RBS self web page services back. It was available on the 8 series early on but someone decided to take it away. Would have been nice to have it here.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
x19
Sep 20, 2022Guide
Think I upgraded the firmware on the RBS by going into their console using the IP address showing on Orbi App. There was a limited console available
Sep 20, 2022Guru - Experienced User
Telnet?
- x19Sep 20, 2022Guide
No just https://orbi satellite IP
- FURRYe38Sep 20, 2022Guru - Experienced User
See if you can get in. I would presume if the RBS isn't synced that the RBS web page won't be accessible via IP address...
Didnt work either with the cable, the satellites were still showing up as disconnected and no IP. Went into the Orbi APP and was showing 0 satellites, but when clicking on network map their were showing in red and disconnected. However their IP was in the details and I was able to access the IP and downgrade satellite first and then main router
- CrimpOnSep 20, 2022Guru - Experienced User
You connected a cable directly to the satellite and entered the satellite IP address into the web browser?
or
You were somewhere else on the network and entered the satellite IP into the web browser?
So you go the system downgraded to v.85?
No I connected the router to the satellite via cable and then connected to the satellite IP as in the network map it was still showing as disconnected.
Yes downgraded all to .85
Enjoy. 📡
