x19's avatar
x19
Guide
Feb 09, 2023
RBK963 make over
A bit of make over to the standard Orbi...
Liquid vinyl spray and USB blue Led strip always on.
Really would like the Led to be on all Orbis as standard.....
  • plemans's avatar
    Interesting look. Hopefully it doesn't void the warranty if you have any issues
    • x19's avatar
      x19
      Guide
      It is a beta unit... Also the led strip can easily be removed and the vinyl paint is the same I used on the alloy wheels of the car which can be peeled off. Not 100% sure but on plastic should be the same
      • plemans's avatar
        Good to hear its a beta unit. Not much support on those except for the beta crew.
        Nice little upgrade to make it stand out a bit more. Funny cause usually you see people asking for less light on them 🙂
