Yld2rob
Mar 08, 2022Luminary
RBK963 Mystery Satellites appearing when using wired backhaul
So I set up my new Orbi system first wirelessly. The orbi app and the website shows one router and 2 Satellies. Makes sense right? Not if I connect ethernet to the router and satellies via via CAT7 c...
Yld2rob
- Mikey94025Mar 08, 2022Hero
I would also check the orilogin.com web admin portal and see if it shows the same extra/unexpected satellites. If no, then assume it's just an app issue and ignore it. If yes, we have different next steps to try.
