Yld2rob
Mar 08, 2022Luminary
RBK963 Mystery Satellites appearing when using wired backhaul
So I set up my new Orbi system first wirelessly. The orbi app and the website shows one router and 2 Satellies. Makes sense right? Not if I connect ethernet to the router and satellies via via CAT7 c...
Mar 29, 2022Guru - Experienced User
Any progress on this?
Yld2rob wrote:
So I set up my new Orbi system first wirelessly. The orbi app and the website shows one router and 2 Satellies. Makes sense right? Not if I connect ethernet to the router and satellies via via CAT7 cables. I get 2 satellies and then one or 2 more satellies appear as Satellie-1 and satellie-2. What is going on sometimes I am able to remove these "Ghost" satellies, but they just reappear. I have the router and the 2 satellies connected into a unmanaged switch. See the photo for the current network map. What is going on?
