Ralyrt
Jan 26, 2023Aspirant
RBKE 963 (AXE11000) router ports not working
Brought new set up well all works fine beside the ports on the router spent 7 hours on the phone over 2 days only to be told it must be faulty so returned it for new one and guess what exact somethin...
Jan 26, 2023Guru
What ports are not working?
And 2nd system is doing same thing?
What are you connecting to the RBR?
Does wireless work ok?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
