Ralyrt
Jan 26, 2023Aspirant
RBKE 963 (AXE11000) router ports not working
Brought new set up well all works fine beside the ports on the router spent 7 hours on the phone over 2 days only to be told it must be faulty so returned it for new one and guess what exact somethin...
schumaku
Jan 26, 2023Guru - Experienced User
Unlikely these ports don't work. Checked this? How do I set up my NETGEAR router if I have Vodafone NZ Fibre or UFB?
Ralyrt
Thank you all cables need to be CAT5E or CAT6 or higher so that's the problem for half to it and the TP link 24 port smart switch is the other so now on to tp link to see why
- FURRYe38Jan 26, 2023Guru - Experienced User
Do wired devices work directly connected to the RBR with out any switch connected?
What is the model# of the TP-Link switch?
- RalyrtJan 29, 2023Aspirant
I connect a switch to the Orbi model TL-SG1024DE and all it says your connected to the network but not to the internet, this mesh system has proven to be some what difficult to set up for some reason
- FURRYe38Jan 30, 2023Guru - Experienced User
