Ralyrt
Jan 26, 2023Aspirant
RBKE 963 (AXE11000) router ports not working
Brought new set up well all works fine beside the ports on the router spent 7 hours on the phone over 2 days only to be told it must be faulty so returned it for new one and guess what exact somethin...
Ralyrt
Thank you all cables need to be CAT5E or CAT6 or higher so that's the problem for half to it and the TP link 24 port smart switch is the other so now on to tp link to see why
Jan 26, 2023Guru - Experienced User
Do wired devices work directly connected to the RBR with out any switch connected?
What is the model# of the TP-Link switch?
- RalyrtJan 29, 2023Aspirant
I connect a switch to the Orbi model TL-SG1024DE and all it says your connected to the network but not to the internet, this mesh system has proven to be some what difficult to set up for some reason
- FURRYe38Jan 30, 2023Guru - Experienced User
- RalyrtJan 30, 2023Aspirant
Hey yes they do currently have it directly plugged in.
Do you think there is a setting in the router i need to alter?
