Routerpr0blem
Jan 22, 2025Aspirant
Rbke 963 best settings
Hey, I got the rbke963 white edition 1 router 2 satelites acting in ap mode. My modem of provider shares the network with router of orbi. The point is network is dropping sometimes and I touch I...
Routerpr0blem
Hey
Firmware = V7.2.6.31_5.0.24
My internet provider is KPN from the Netherlands with there modem experia box v12
from the modem to the orbi router there is etl verified cat.6 stp see picture but behind there is hanging the modem behind the modem there is a optic fiber box
the home is not big 128m2 3 floors first and second floor has satalite where is 10meter behind of each other but.
where the router is located directly above where below the router is located the same place as the satellite is located above. If you calculate this, it is only 7 meters with a concrete ceiling in between.
the are wireless connected each other. I dont have the option with cable at the other floors.
What do you mean with rbs turned off?
I dont have wired devices using full of wireless connections also my devices like camera, washing mashines ect on 2.4ghz networks the kicked out sometimes where I cant see them from the app anymore. meanwhile the satalite at second floor is almost next to these devices.
those are the channel configs:
| Europa | |
| 2.4 GHz Kanaal | Automatisch (8) |
| 2.4 GHz Draadloze modus: | Up to 1147 Mbps |
| 5 GHz Kanaal | 36 + 40(P) + 44 + 48 |
| 5 GHz Draadloze modus: | Up to 2402 Mbps |
| 6 GHz Kanaal | 65 + 69(P) + 73 + 77 + 81 + 85 + 89 + 93 |
| 6 GHz Draadloze modus: | Maximaal 4804 Mbps |
I use all dynamic.
Jan 23, 2025Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
For that size of home, having too many RBS deployed could cause problems. Something to try, Turn down the power on the RBR from 100% to 50% and see. Under Advanced Tab/Advanced Settings/Wireless Settings
Turn OFF one RBS to see if issues are still seen.
Might try manual channel 1, 6 or 11 on 2.4Ghz.
Been posts about v.31 not working well for users after it's loaded. May need to go back to prior working FW version.
- Routerpr0blemJan 23, 2025Aspirant
Hey,
WHat u mean with rbs? I dont see it or u mean this settings? and it should work till 600m2 I mean thats big... ALso the standard things ive reseted and restarted already many times.
How the backhuel works? it is also currently out of sync
- FURRYe38Jan 23, 2025Guru - Experienced User
RBS = Satellites.
Having too small of a home size with too many RBS deployed and cause wifi signal problems or too much wifi signal over lap between the units.
Has this system worked well since you got it or just recently exhibited some problems?
When was the FW updated?
Well I have them currently 7 months but since in this 6.5 months ive used it as a router and I saw later I could swap to ap mode so I did this 2 weeks ago. The reason I did this was because facetime from whatsapp ect was laggy I had all time to swap to my ssid of my modem of my provider. On that ssid never lagspikes. I had before powerline adapters It was fine till I swapped to orbi's reason I upgraded my incomming network from 200mb down up to 1gb. The firmware was updated 7 months ago in the setup proces. I've also now turned off auto update of firmware. But how Can I select per RBS to downgrade there power.
