Routerpr0blem
Jan 22, 2025Aspirant
Rbke 963 best settings
Hey, I got the rbke963 white edition 1 router 2 satelites acting in ap mode. My modem of provider shares the network with router of orbi. The point is network is dropping sometimes and I touch I...
Jan 27, 2025Guru - Experienced User
If you directly connect the RBS using the high speed port, between them use these ports. If your only using the 1Gb port on the RBR then use the 1Gb port on the RBS. There is CAT6 UTP and CAT6A STP. CAT6 UTP can be used for the 1Gb ports. Recommend using CAT6A STP for the high speed ports, 10Gb and 2.5Gb. There is no CAT6E.
Routerpr0blem
Jan 30, 2025Aspirant
Hey
ive moved the satelites one satalite is now also with cable connected but still having issues that sometimes the orbi loses each other. Also on whatsapp facetime calls or camera views are slow. No trouble with gaming at all but those things need be fine too.
- FURRYe38Jan 31, 2025Guru - Experienced User
v.31 has been reported as no working well for users. We've been recommending users revert back to v.21 if your in the NA region, if EU or ROW regions, then you'll need to revert back to v6 FW.
Downgrade the RBS first then RBR lastly. After the system has been downgraded, factory reset the system and setup from scratch OFFLINE from the ISP services. After setup has been completed, disable the Auto Update feature on the RBR to prevent v.31 from being re-loaded. Then connect back to your ISP services.
