ArunGupta's avatar
ArunGupta
Apprentice
Nov 25, 2022
RBKE 963 Where is QoS and WMM?
Firmware level 6.3.7.5. Cannot find QoS and WMM. They are listed in the Orbi manual and I am certain they were present  when I purchased the router. The only things that has changed is FW updated to 6.3. Has Netgear removed them with the 6.3 FW?
Thanks,
Arun
  •  It might be worth mentioning that this WiFi Multi Media (WMM) Quality of Service is entirely different from the Quality of Service setting that customers often look for. Such as, for example, to specify that their gaming PC get a higher QoS than any other device on the network, no matter what it happens to be doing.
    • CrimpOn's avatar
      CrimpOn
      • ArunGupta's avatar
        ArunGupta
        Apprentice
        That's fine if they removed it. I never used it, but wanted to make sure that it was really gone.
