jmvtev
Nov 04, 2023Aspirant
RBKE953S FIRMWARE
Does anyone know if there will be an update to the RBRE953S firmware? Seems like it has been forgotten. It is the RBRE950 sold at Costco.
- Dec 27, 2023
Just install the current RBRE960 firmware. It works fine on both the satellites and the main gateway. Attached is my system after I updated.
jmvtev
Nov 05, 2023Aspirant
Thank you. Just concerned about security and hoping they will add a little more customization to the settings. Like the ability to select other channels than what is available now.
Nov 05, 2023Guru - Experienced User
You should be ok for now.
Channel selection won't change from what already offered. Orbi systems only supports certain channels for user selection.
