jmvtev
Nov 04, 2023Aspirant
RBKE953S FIRMWARE
Does anyone know if there will be an update to the RBRE953S firmware? Seems like it has been forgotten. It is the RBRE950 sold at Costco.
- Dec 27, 2023
Just install the current RBRE960 firmware. It works fine on both the satellites and the main gateway. Attached is my system after I updated.
apanola
Dec 27, 2023Aspirant
jmvtev
Thank you Apanola. I'll give it a shot. How long have you had it on that firmware? Any issues?
- apanolaJan 14, 2024Aspirant
About 2 months now, no issues so far.
- FURRYe38Jan 14, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
