jmduraes
Mar 26, 2022Aspirant
RBKE960 - wired backhaul over 10Gbe port
Hello all, I have an RBKE963 (960, 3 pieces) system, with one router (RBRE960) and two satellites (RBSE960). I have a 2Gbps fibre connection to the home. The router is configured as an Access...
Mikey94025
Mar 26, 2022Hero
jmduraes wrote:The other satellite is connected to my main switch (the same as the router) over its 2.5Gbe port. I cannot get wired ethernet backhaul to work on this one. Wireless backhaul (if I disconnect the ethernet cable) works fine.
What kind of switch is it? Managed switches cause problems with wired backhaul, so we usually recommend certain unmanaged switches for the Orbi router+satellites connectivity.
jmduraes
Mar 27, 2022Aspirant
It's an unmanaged switch.
- FURRYe38Mar 27, 2022Guru - Experienced User
The 10Gb port is only for the WAN side. Any changes to 10Gb would be a HW change. Still not a lot of users with 10Gb needs on the LAN side and that speed supporting hardware is still moderately expensive for Switches and ethernet adapter cards. Also to really take advantage of 10Gb, devices like PCs and laptops, NAS need fast CPUs and boards to deal with that much data at that speed. Why some 2.5Gb ethernet cards have large heat sinks on them. The faster the speed, that hotter things get. Many factors contribute to 10Gb speeds.
Overall the 9 series works well for back haul on 2.5 and 1Gb. You just need to ensure that your using matching speed and supporting switches if you want 2.5Gb speeds across the board. CAT6 lan cable at minimum for interconnecting Orbi devices.
