69matrix69
May 18, 2023Tutor
RBKE960 power adapters needed or model number for power adapter needed
I just moved from PA to SC and my movers lost some of my things as they shipped a 2nd load with my stuff. I unpacked my Orbi RBKE 963 router and 2 satellites but I can't find the power adapters for a...
- Apr 23, 2024
Ok, Good news, this particular PS arrived to day and has correct sized plug that works for the 960 series:
https://www.amazon.com/Kircuit-Compatible-332-11588-01-3321158801-PY321200536/dp/B0CH3FW3HS
I was only able to connect and power ON for a short while. I'll be sending this back.
Hopefully this is a good alternative for users that may need one if the stock PS goes back or gets lost or damaged.
This may work for NGs CAX80 gateway modem and RAXE500 router as well since these two have same larger barrel center pin as the 960 has.
CrimpOn
May 18, 2023Guru - Experienced User
The model number mentioned by plemans is available on Amazon for $20.
69matrix69
May 18, 2023Tutor
I just ordered one of the adapters. One of the "The model number mentioned by plemans is available on Amazon for $20." It will arrive Saturday. I'll let you know if it works or not and if it is right I'll order the other 2. At this point I have almost 200 dollars into buying power adapters.
- plemansMay 19, 2023Guru - Experienced User
Hopefully it works well for you!
Impressive that you've invested that much in power adapters and still don't have the correct one.
Darned shippers losing boxes.
