69matrix69
May 18, 2023Tutor
RBKE960 power adapters needed or model number for power adapter needed
I just moved from PA to SC and my movers lost some of my things as they shipped a 2nd load with my stuff. I unpacked my Orbi RBKE 963 router and 2 satellites but I can't find the power adapters for a...
- Apr 23, 2024
Ok, Good news, this particular PS arrived to day and has correct sized plug that works for the 960 series:
https://www.amazon.com/Kircuit-Compatible-332-11588-01-3321158801-PY321200536/dp/B0CH3FW3HS
I was only able to connect and power ON for a short while. I'll be sending this back.
Hopefully this is a good alternative for users that may need one if the stock PS goes back or gets lost or damaged.
This may work for NGs CAX80 gateway modem and RAXE500 router as well since these two have same larger barrel center pin as the 960 has.
May 18, 2023Guru - Experienced User
mine is pn 332-11480-02
model ad2003f10
May 19, 2023Guru - Experienced User
Interesting, your model adapter is different from mine.
Does your 9 series have the larger center pin or the micro one? Mine has the large center pin.
model ad2003f10
- 69matrix69May 20, 2023TutorI received the power adapter from Amazon today and ONCE again it was wrong. The center barel size on my routers are big and all the power adapters that I have received have been too small. I took a picture of the latest one that I just got today next to the plug hole. The issue I have had are none of the barely sizes are the large center post. The previous 800 series routers and the nighthawk routers used the smaller center barely like I have received I think but they changed it for the 900 series. (From what I have found out the hard way)
- plemansMay 20, 2023Guru - Experienced UserLook at the modem number on the adapter. See if it's the same. I've had them send the wrong ones
- FURRYe38May 21, 2023Guru - Experienced User
2AEC0060K 1 is MODEL # seen on my 9 series PS. This is the one with the large center pin on mine. Same as yours.
69matrix69 wrote:
I received the power adapter from Amazon today and ONCE again it was wrong. The center barel size on my routers are big and all the power adapters that I have received have been too small. I took a picture of the latest one that I just got today next to the plug hole. The issue I have had are none of the barely sizes are the large center post. The previous 800 series routers and the nighthawk routers used the smaller center barely like I have received I think but they changed it for the 900 series. (From what I have found out the hard way)- 69matrix69May 22, 2023TutorIf I search for "2AEC0060K" on Amazon or the Google it finds 0 power adapters. I tried searching for both 2AEC0060K and 2AEC0060K 1 so do you have any more information or links for me?
